What does "wrapper" stand for ?
ajhsu
Full Member level 4
I saw a block named "wrapper" in the chip system diagram.
Could someone advise what does it mean ?
Thanks.
Thomson
Full Member level 3
You can take it as a bridge which connects two different interfaces! Of course, the concept of bridge doesn't just connect two different interfaces, e.g. PCI bridge.
A wrapper is sometimes just to refer to one smaller block used to connect the current inferface to the new interface so that these two different interfaces can be commnunicated now! This ofter happens when you buy a off-the-shelf IP that is not compatible with your current bus! For example, one Wishbone interface and one AHB interface!
When the Wrapper is rather robust/functional/configurable, now it can be conceived of it as a Birdge, more suitble!
Maybe helpful!
Thomson
manu_leo
Member level 1
bangalore
Wrapper is something which helps in interfacing,
For eg, i need to do memBIST, in that case i need to separate the functional logic from the test logic, then i add some muxes around memory, which forms a wrapper
funzero
Full Member level 4
In some cases , you will import an external IP to your system , but the interface will not full satify your reqirements . you have to write some code in order to make the IP work . the code you write is sometimes call " WRAPPER " .
beejan
Junior Member level 2
Another very good example for wrapper application is asynhronous synhronous domain mix in a design. Or when we design a GALS besd system we have to think about wrappers.
C4Cheema
Member level 3
Spain
I have AHB2AHB Bridge I want to write XBUS wrapper inside it
Will you guide me what amendments should I need to do.
