Major (read all) :wink: of the synthesis tools like XST, Synplify Pro. support retiming..
Excerpt from Xilinx Synthesis Technology (XST) User Guide..
"Retiming is a technique that consists of moving flip-flops
and latches across logic for the purpose of improving timing, and so
increasing clock frequency.Flip-flop retiming can be either forward
or backward. Forward retiming will move a set of flip-flops that are
the input of a LUT to a single flip-flop at its output. Backward
retiming will move a flip-flop that is at the output of a LUT to a set of
flip-flops at its input. Flip-flop retiming can significantly increase the
number of flip-flops in the design, and it may remove some flip-flops.
Nevertheless, the behavior of the designs remains the same. Only
timing delays will be modified...."
Excerpt From Synplify Pro User Guide..
"syn_allow_retiming
Attribute; Xilinx and Altera. The syn_allow_retiming attribute determines
whether registers may be moved across combinatorial logic to improve
performance in Xilinx Virtex and Altera APEX, APEX II, FLEX10K, Excalibur,
and Mercury architectures..."
