What does the group delay mean?
deepa
Full Member level 2
does group delay mean the phase of the system
Re: group delay
HI DEAR,
In physics, and in particular in optics, the study of waves and digital signal processing, the term group delay has the following meanings:
1. The rate of change of the total phase shift with respect to angular frequency,
through a device or transmission medium, where is the total phase shift in radians, and is the angular frequency in radians per unit time, equal to , where is the frequency (hertz if group delay is measured in seconds).
2. In an optical fiber, the transit time required for optical power, traveling at a given mode's group velocity, to travel a given distance.
Note: For optical fiber dispersion measurement purposes, the quantity of interest is group delay per unit length, which is the reciprocal of the group velocity of a particular mode. The measured group delay of a signal through an optical fiber exhibits a wavelength dependence due to the various dispersion mechanisms present in the fiber.
Source: from Federal Standard 1037C
It is often desirable for the group delay to be constant across all frequencies; otherwise there is temporal smearing of the signal. Because group delay is , as defined in (1), it therefore follows that a constant group delay can be achieved if the transfer function of the device or medium has a linear phase response (i.e., where the group delay is a constant). The degree of nonlinearity of the phase indicates the deviation of the group delay from a constant.
[edit] Group delay in the audio field
Group delay has some importance also in the audio field and especially in the sound reproduction field. Many components of an audio reproduction chain, notably loudspeakers and multiway loudspeakers crossover networks, introduce group delay in the audio signal. It is therefore important to know the threshold of audibility of group delay with respect to frequency, especially if the audio chain is supposed to provide a high fidelity reproduction. At the time of writing no extensive data is available, and the concept is often treated by "rule of thumb" or based on hunches and received wisdom. The best thresholds of audibility table has been provided by Blauert and Laws:
Frequency Threshold
500 Hz 3.2 ms
1 kHz 2 ms
2 kHz 1 ms
4 kHz 1.5 ms
8 kHz 2 ms
