What does ppm stand for ?
andyyau
Junior Member level 2
What is "ppm"
When talking about temperature coefficient of electronic components, they are always specified in ppm.
What is it? Please give a explanation.
Thanks!
hwswboy
Member level 4
Re: What is "ppm"
ppm=parts per million
mtawab74
Member level 3
Re: What is "ppm"
would u please give us a clear example abt PPM meaning
DavidP
Member level 1
Israel
If a componennt has 100ppm temp. coeficient it means that if the temperature will change with 1 degree celsius from a reference temperature then the value of the component will change with 100ppm which means with +/- 0.0001xcomponent value.
For example a resistor of 100k will become 100k +/-10 R (100,000x0.0001)
David
FFFFFF
Full Member level 1
LUNAPARK
Re: What is "ppm"
example for 1 p p m :
i measure a lenght of 1 000 000 meters and i have an error of 1 meter !!
thrue length is 9 999 999 < value < 1 000 001 ...
for 2 p p m
thrue lenght is 9 999 998 < value < 1 000 002
and ....
6 * F
flatulent
Advanced Member level 5
Middle Earth
history
As science developed and measurements and manufacturing became more precise, the characterization of error less than 1% when expressed in % had a lot of leading zeros. In order to make the numbers more manageable, parts per million were introduced. When things became more precise parts in 10^n type formats were introduced.
This measurement can also be used to show the ratio of a small quantity mixed in a larger quantity, either by number of molecules or by weight. Gas detectors are rated in the ppm concentrations they can detect.
electronrancher
Advanced Member level 1
mtawab74 - i do switchers... as for seminars. - sure i have some - what have you read? i can probably send you some stuff, but unless you like switchers it's not too interesting.
tlp71@hotmail.com
Full Member level 4
Re: What is "ppm"
ppm is part per millions.
is an specification for devices that said the quality.
Ex. the oscillator is +-50ppm means that if your frequency is 10 mhz you can have an error of +- 500 Hz.
Bye
homeadd
1PPM=1/1000000;
Example:+/-50PPM means that the actul value may be
(x)-(50/1000000)*(x)<=(x)<=(x)+(50/1000000)*(x);
H
hienpv
if you call x is your expect value,
y is your real value
so ppm = abs(x-y)/x
Mr.Cool
Advanced Member level 2
Re: What is "ppm"
another thing to remember is that PPM is a linear relationship. in simulation software you find this as the "linear temperature coefficient". there are quadratic and exponential temperature coefficients too.
but datasheets usually have only the linear relationship
Mr.Cool
