VladZ
Member level 2
Pease explain me what does mean "over voltage protection" in in AC/DC switching adapter characteristics ?
For example I see the following characteristics:
VOLTAGE : AC INPUT 90Vac TO 264Vac, FULL RANGE
OUTPUT REQUIREMENTS:+15 V, RATE LOAD 2.2 A
PROTECTION :
OVER LOAD PROTECTION : AROUND 150 % RATE LOAD AT 115Vac (230Vac).
OVER VOLTAGE PROTECTION : RANGE FROM 16.5 TO 19.5VDC.
As I know switching adapters can drive hard loads. Does mentioned above
mean that on weak loads I will abtain 16.5 TO 19.5VDC, although the nominal output is +15V?
Thanks in advance
vladz
PROTECTION :
Thanks in advance
vladz
