What does Balun mean and why we use it ??
khouly
Advanced Member level 5
EGYPT
Re: what's Balun ??
balun is a differential to single ended conversion circuit
khouly
ajhsu
Full Member level 4
Re: what's Balun ??
Hope these are helpful.
ahmad_abdulghany
San Jose, California, USA
Re: what's Balun ??
ahmad_abdulghany said:
I want to know simply, what does Balun mean? and why we use it?
also Sleeve antenna???
Thanks in advance,
Ahamd,
kolarbear
Member level 2
what's Balun ??
very good article about balun.
mshareef
Member level 3
Re: what's Balun ??
Let me try:
The word balun means balanced-unbalanced: it's used to adapt a balanced device to an unbalanced one; in a balanced device (as larger type of antennas) we have on both terminal the same voltage respect to the ground (if not so it's an unbalanced device); a dipole with direct feed is balanced, a coaxial cable is unbalanced. Why balun is used/ You can read further at: https://www.qsl.net/iz7ath/web/02_brew/11_balun/pag01_eng.htm
And if you want to build a balun then read its use and hows at: https://www.hamuniverse.com/balun.html
