What does ^ and v symbols in timing report represents?
biju4u90
Full Member level 3
This is a part of the timing report file of my design.
Path 1: VIOLATED Setup Check with Pin U_FFT2/\dr_reg[13] /CLK
Endpoint: U_FFT2/\dr_reg[13] /SIN (^) checked with leading edge of
'CLK'
Beginpoint: U_BUF2/URAM/\read_addra_reg[1] /Q (v) triggered by leading edge of
'CLK'
In this report, what does the ^ and v symbols in SIN(^) and Q(v) represents?
jbeniston
Advanced Member level 1
Rising transition / falling transition, I think.
biju4u90
Full Member level 3
Is there any significance for the rising/falling transition of beginpoint/endpoint of data path? The rising/falling transitions in these pins should be input dependent, right?
artmalik
Full Member level 5
San Diego
there is nothing like "input_dependant"...the tool will analyze both rise and fall paths for any constraint. it is needed for getting the worst case. the same applies to clock tree as well.... all this is correlated with spice for tool deployment.
biju4u90
Full Member level 3
@artmalik: While checking setup violations, I had a path like this with violation.
Endpoint: U_FFT2/\dr_reg[13] /SIN (^) checked with leading edge of 'CLK'
Beginpoint: U_BUF2/URAM/\read_addra_reg[1] /Q (v) triggered by leading edge of 'CLK'
I resized the buffers in the path for fixing the violation. When I tried to report the timing result of the path, I got the report like this.
Beginpoint: U_BUF2/URAM/\read_addra_reg[1] /Q (^) triggered by leading edge of 'CLK'
Why does the edge at the Q pin changes? Also, when I check the timing report, it was seen that the path from Q(^) to SIN(^) contains different instances now!
