what does 3dB bandwidth means for ADC input
syedshan
Advanced Member level 1
Jeonju, South Korea
hello every one,
I am using AD62P49 ADC. In the ADC data sheet I come accross the following statement and I cannot actually understand what it exactly mean here by 3 dB bandwidth and then what does it mean by HIGH 3-dB bandwidth.
The input sampling circuit has a high 3-dB bandwidth that extends up to 700 MHz (measured from the input pins to the sampled voltage).
Thans
The term "HIGH 3-dB bandwidth" isn't used in the datasheet as far as I'm aware of. I assume, you're confused that ADC behaviour for frequencies above the Nyquist rate is specified?
It's particularly interesting in undersampling applications, for a brief overview see: https://en.wikipedia.org/wiki/Undersampling
I believe it's referring to the -3dB high frequency response point for the input circuitry prior to the sampling circuitry.
It's not only the bandwidth of the input circuitry prior to the sampling circuitry, it's essentially determined by the aperture time, the width of the sampling window.
Hi FvM:
Does it mean the bandwidth of the sampled circuit ?
If I have any mistake, please correct me.
mpig
I think it is a drafting error or misuse of the term; the correct term should be "WIDE bandwidth".
"High bandwidth" and "low bandwidth" appear several times in the data sheet where "wide" and "narrow" would fit better.
Z
