ruwan2
Member level 5
- Joined
- Nov 29, 2011
- Messages
- 90
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 2,141
I have a code run well with Microsoft Visio Studio Express 10.0, but I would like to run with Modelsim which has MINGW4.2.1. I find that the file write operation fails. If I comment out the file operation part, it works.
What requirement for SystemC 2.3.1 work with Modelsim?
BTW, how to know the SytemsC library version in Modelsim? I can see that when run MSVC, Windows, but no such info in mingw4.2.1 under Modelsim.
The code is attached below.
Thanks a lot,
.h file:
.c file:
Thanks a lot,
.h file:
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 #define FILE_WRITE 1 /* #undef FILE_WRITE */ struct fir: sc_module{ sc_in<bool> reset; sc_in<bool> input_valid; sc_in<int> sample; sc_out<bool> output_data_ready; sc_out<int> result; sc_in_clk CLK; int index; #ifdef FILE_WRITE FILE* fp_real;// ofstream myfile; #endif sc_int<9> coefs[16]; SC_CTOR(fir) { SC_CTHREAD(entry, CLK.pos()); reset_signal_is(reset,true); #include "fir_const.h" } void entry(); #ifdef FILE_WRITE ~fir() { fclose( fp_real ); } #endif };
.c file:
Code C++ - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 void fir::entry() { sc_int<8> sample_tmp; sc_int<17> pro; sc_int<19> acc; sc_int<8> shift[16]; sc_uint<16> val; //variable to hold data int tmp_out; // reset watching /* this would be an unrolled loop */ #ifdef FILE_WRITE fp_real = fopen("out_example.txt","w"); #endif for (int i=0; i<=15; i++) shift[i] = 0; result.write(0); output_data_ready.write(false); wait(); // main functionality index=0; while(1) { output_data_ready.write(false); do { wait(); }while ( !(input_valid == true) ); sample_tmp = sample.read(); acc = sample_tmp*coefs[0]; for(int i=14; i>=0; i--) { /* this would be an unrolled loop */ pro = shift[i]*coefs[i+1]; acc += pro; }; for(int i=14; i>=0; i--) { /* this would be an unrolled loop */ shift[i+1] = shift[i]; }; shift[0] = sample_tmp; // write output values result.write((int)acc); output_data_ready.write(true);/* myfile << "shift[xxxxxx]"; myfile << "index=" << index << endl; cout << "index=" << index << endl;*/ #ifdef FILE_WRITE // fprintf(fp_real,"%d \n", tmp_out); #endif index++; wait(); }; }
