what difference between RC filter or LC filter?
sethtalk
Member level 3
taiwan
lc vs rc filter
tks!!
difference between rc and lc filters
RC implemented with only R and C
in order to get L for Bandpass function, you need
gyrator which convert the C to L.
and LC implemented with both L and C.
    sethtalk
difference between rc and lc circuit
you means the RC filter (composed of only R & c) can build LPF and HPF,
but it can't build BPF ?
RC or LC can build either LPF/HPF
LC can build BPF also
--- R ----- is a LPF. Replace R by L it is a second oder LPF. swap Comps to
| get HPF
C
----L--C---- is BPF
---- L||C -- is BRF/Notch .... so on
Hope this helps
    sethtalk
difference between l and c filters
tks!!
High Q of LC than RC
    sethtalk
