What code should be used for 8 bit current mode DAC?
wany
Member level 2
About current mode DAC
i will do a 8bit curren mode DAC. what kind of code should i use. is it binary or thermometer. Thank you !
jlee
Member level 2
Re: About current mode DAC
It depends on your spec. The differences between two are mainly:
Binary code: Smaller area(no decoder and few switches), worse DNL, same INL.
Thermometer/Unit-element code: More area(needs decoder and much more switches), better DNL, same INL.
As a tradeoff, most people use a mixture of both. MSB bits are in thermometer code, LSB bits are in Binary code.
I read a very good paper about this topic before, it is a reference in Berkeley's EE247 ADC class. Highly recommend!!!
    wany
omsi
Member level 5
London
Binary
    wany
wany
Member level 2
thank you jlee and omis .But omis why do you affirm to use binary? The sample rate of the DAC is 100MHz.
yaxazaa
segmentation may be better.™
waosai
Member level 2
generally speaking, thermometer code is used when bit<=8bit while segmentation is used when bit >8bit
