What can I use to build a fingerprint scanner?
3wais
Member level 4
Alexandria,Egypt
What can I use to get Fingerprints ?
I have read something in wikipedia that says Optical and Capacitance and Ultrasonic sensors can be used for this
can the usual touch panels be used ?
or where can i get any of these sensors to interface with a microcontroller ?
I dont want a ready module or scanner . i want to do one myself !!
eagledot
Member level 1
Re: Finger Print Sensing
It ought to use something that has a wavelength less than the distance between two groves of a fingerprint.
Reactions: 3wais
    3wais
3wais
Member level 4
Alexandria,Egypt
Can you be more specific ??
do you mean generating a wave with wavelength less than the groves then recieving it back ?
how can this be done ?
tpetar
Advanced Member level 5
Pancevo-Belgrade, Serbia
Capacitance Scanner
https://computer.howstuffworks.com/fingerprint-scanner3.htm
eagledot
Member level 1
In other words, you better build a chip fab or buy a capacitor matrix ;)
(and integrated op-amp for each point, and read out arrangement to add to the pain)
Other than that some kind of scanner may solve it. Be it ultrasonic, laser scan etc..
Though the capacitive approach resist dirt.
Reactions: 3wais
    3wais
tpetar
See this :
Cop’s homemade fingerprint scanner
https://www.punemirror.in/index.asp...d=200912232009122303250247322e9bcf6&sectxslt=
---------- Post added at 04:44 ---------- Previous post was at 04:41 ----------
Ultrasonic scanners have the ability to scan beneath the skin. This gives the scanner the ability to verify that there is a live person present. These provide a high level of security, but are slower than others.
Capacitive scanners are more resistant to contamination by dirt and debris than other scanners. They are also more susceptible to interference by static electricity
Optical scanners often include an LED light that is used to illuminate the fingerprint. The sensors use this light to scan the fingerprint. Its dependency on light, though, makes it susceptible to interference from ambient light.
