What are the types of oscillators?
mxyzptlk
Types of Oscillators
If we should go about categorising oscillators how many categories will be there?
Ring Oscillators - which depend on the inversion of the stage to cause the oscillation, and on each stage's propagation delay for the frequency
Relaxation Oscillators - which depend on chargins and discharging a node to get the delay and one inversion to get the oscillation
What else?
mkhan
Full Member level 3
Re: Types of Oscillators
If you provide positive feedback (i.e. on positive terminal of op-amp) in operational amplifier, then it works as an oscillator as well.
BR,
Arif Khan
mxyzptlk
Yes that is normally a relaxation oscillator since it is based on charging/discharging a capacitor. There are phase shift oscillators based on opamps
Some other types of oscillators are: (correct me if I am wrong..)
LC Oscillators (By utilizing some negative resistance circuit to build LC tank oscillations) (e.g. Colpitts? Hartley?)
Then there are Phase Shift Oscillators, which provide a phase shift of 360 in the loop at a particular frequency to generate oscillations at that frequency. (e.g. Wein Bridge Oscillator)
Then I have heard of emitter coupled oscillator, does it lie in any of the above categories? What is its principle of functioning?
haley_8
Junior Member level 2
Colpitts and Harley Oscillators...
maharshi_qis
Full Member level 5
oscillators are 2 types..
1.sinusoidal
2 .non sinusoidal
Colpitts and hartley all are sinusoidal osci which r based on bharkausen criterion
Relaxation ,ring osci. are non sinusoidal..
