What are the drain extended devices and LDD ?
sunileda
Newbie level 3
Hi all ..
CAn anyone tell me about drain extended devices and LDD ,
griffin77
Newbie level 2
DEMOS
LDD- lightly doped drain, it is normally used to increase the voltage of the device, and can be found in most high voltage device.
layoutmaster
Full Member level 3
DEMOS
LDD and the extension of device's drain are the usual techniques to make higher breakdown voltage devices.
Usually a combination of both techniques are used to generate a "family of devices" with steped breakdown volgates.
Lower voltage ones have nothing about it, next level add the LDD and later levels use to extend more and more the drain until a total of, usually, no more than 4 to 5 different available devices. About the voltages values, it's process dependent.
