[SOLVED] What are the common methods to find the order of an FIR filter with given spec?
blooz
Advanced Member level 2
India
What are the Common method to find the order of the FIR filter When specifications
1.Stopband
2.Pass band
3.Stop Band Attenuation
4.Pass Band Attenuation
are given
Window methods .....or Else directly ?
Filter order = 4 /Normalised width of transition band normally works out!
Reactions: blooz
    blooz
The order of a filter will determined the fall-off from the -3dB frequency to the stop band.
2 nd order 20 dB/decade or 6 dB/octave
4 th order 40 dB /decade
Reactions: blooz
    blooz
