Regular STA (Static Timing Analysis) propagates cell and wire slews and delays to calculate the timing slack on paths
SSTA (Statistical Static Timing Analysis) propagates delay distributions to calculate cell the delay (mean and sigma) of timing paths.
What advantages you get :
The margins used for SSTA will only need to account for other components such as IR and fab-to-fab mismatch.
where as STA , need to consider process variation apart from the above margins. these process variations will be diferent for each run, which we can avoid with SSTA.
