saulbit
Member level 4
I am confronted a difficult to make the RF signal FM modulated. I don't have good knowledge about the FM modulation. I learnt from something that if the reference is FM modulated, then the VCO output of the PLL would be also FM modulated. However, the loop bandwidith is about 100 kHz (I got this from the phase noise curve in the spectrum with phase noise measuring feature, the bandwidth is about 3dB minor than the phase noise hump, please tell me if I am wrong). When I use a reference as 100MHz, 2k deviation and 2k modulation rate, the 2250MHz VCO output shows FM character but with a distortion more than 8%, a deviation about 46kHz, just within the loopbandwidth; when it comes to 200 deviation and 2k modultion rate, the 2250MHz output would be with a deviation of 4.6kHz, a distortion less than 1%. Would someone bring me suggestions about the FM deviation and the loop bandwidth in what case could be fit? Thanks.
