cupoftea
Advanced Member level 5
We are dividing down 390Vdc to 2.5V, then feeding this to a PFC control chip (UCC28070A) which is on a daughter PCB, through the below header and socket housing.......there is no current going through the header pin.....is this OK?....or should we put the lower divider resistor on the daughter PCB, so that at least a few 100 microamps flows through the header connector? (to "wet" the contacts).
Internet re-searching this reveals a huge number of different opinions, without concensus, eg...
www.eng-tips.com
Pin header
Socket for pin header
WETTING CURRENT IN CONNECTOR - Automotive Engineering other topics - Eng-Tips
Hello, I know that for a switch, it is needed a minimum of wetting current (normally 10mA). But is it needed for a connector? Imagine a plug-in module, there is
Pin header
