Well known LVS problem using DIVA
godardth
Sherbrooke QC, CA
diva lvs
It seems that my problem is a well-known one.
I got this log when I tried to do a LVS :
now running "/grp/CMC/tools/cadence.2008a/IC.5141.ISR200811081405/tools.sun4v/dfII/local/.simrc"
finished running "/grp/CMC/tools/cadence.2008a/IC.5141.ISR200811081405/tools.sun4v/dfII/local/.simrc"
Running simulation in directory: "/grp/invite/godt2601/CadenceRep/LVS".
Begin netlist: Aug 12 08:47:01 2009
view name list = ("auLvs" "extracted" "schematic")
stop name list = ("auLvs")
library name = "jopeTestLib"
cell name = "demoInverseur"
view name = "extracted"
globals lib = "basic"
Running Artist Flat Netlisting ...
*WARNING* invalid cell view -- 0(unknown)
global error:
Cannot find switch master cell for instance +1 in cellView (demoInverseur extracted) from viewlist 'auLvs extracted schematic ' in library 'jopeTestLib'.
global error:
Cannot find switch master cell for instance +0 in cellView (demoInverseur extracted) from viewlist 'auLvs extracted schematic ' in library 'jopeTestLib'.
si: Netlist did not complete successfully.
End netlist: Aug 12 08:47:02 2009
Comparison program did not complete.
I have understood that it could be a probleme of CDS_Netlisting_Mode but I tried a lot of unsuccessful things. Here is a list of what I tried :
1) I have verified if my librairies was in the libPath and both tech lib and test lib (where my small test design is) are in
2) In my console (TCSH), I tried to set the CDS_Netlisting_Mode :
setenv CDS_Netlisting_Mode Analog and then start cadence
3) unsetenv CDS_Netlisting_Mode and then start cadence
Could someone give me a solution to my problem ?
Thanks !
PS : The technolgy Lib used is mine and the file divaLVS.rul is mine too but is very simple:
lvsRules(
(pruneDevice general
("nMosEnh" "nMosDep")
(compareDeviceProperty "nMosEnh")
(compareDeviceProperty "nMosDep")
aulvs cell view cadence
Well for DIVA LVS you need to have extracted view.
To get that one you have to run Extract first (Verify -> Extract)
for which you need diva extract rules. Then you run LVS.
From your log is obvious you did not create the extrected view(run extract).
lvs issues diva
I have the extracted view.
Actually I understood that I need an auLvs view for all of the extracted device (for me it is for nMosDep and nMosEnh).
This partially solve my problem but now there is another one :
Begin netlist: Aug 12 15:32:32 2009
*Error* Cell: nMosDep in library: jopeTechLib is missing a
simInfo section in it's CDF for the current simulator.
*Error* artIsCallablep: argument #1 should be either a string or a symbol (type template = "S") - nil
error in instance path /+1:
Error in evaluating property value: 'ancNetlistFileInstOutput()'.
*Error* simNetlistWithArgs:
*Error* Cell: nMosEnh in library: jopeTechLib is missing a
error in instance path /+0:
End netlist: Aug 12 15:32:33 2009
Actually I just did a copy of my symbol views (renamed in auLvs)
And now I have to understand how to create an auLVS view.
Does someone know how to do this ?
diva aulvs
for auLVS you will have to modify the CDf parameters.
For example like this:
Added after 1 minutes:
Sorry here is the pic:
