fofo
Newbie
- Joined
- Jun 8, 2011
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,334
Hello,
After successfully passing the DRC I defined the device correspondences between the schematic and the layout and now I'm running the LVS under ASSORA, It seems that the LVS doesn't use the same data base as the DRC cause the results tell there exist a mismatch between the schema and the layout.
How a device can be well defined and for which reason the LVS doesn't see it???
Then how to define pins,on which layer (met1 pin or pin M1 or what)???
There is a generic resistance that I didn't put myself in the scheme nor in the layout, still the LVS sees it somewhere, any idea???
What the LVW window is for, what to do with it???
I would appreciate your help
