tony_lth
Advanced Member level 5
Hi, Gurus,
I found one weird adjacent channel performance of the SX1268 LORA transceiver.
SX1268 datasheet as attachment "SX1268_V1.0.pdf".
The test setup as "Test_Setup1.lpg", the blue circle is the TX, and the red circle is RX board developed by us.
TX parameters: 484MHz, +10dBm, LORA SF5, PL=55, BW=500Khz,
At CH28, i.e. RX_Freq=484MHz, the RX performance is normal. As attached picture "CH28_RX.jpg", the RX level is about -30dBm.
One channel is 500KHz spacing.
But at CH24, the noise floor level is -70dBm, it should be -100dBm, so it's weird. As attachment "CH24_weird.jpg".
Only when another TX at CH24/482Mhz, and the RX signal level is more than -55dbm, then the RX CH24 performance is normal, as "CH24_normal", the noise floor level is -100dBm.
That is so weird, anyone has the solution?
Best,
Tony Liu
Attached "LORA_SF5_SA.jpg" is the spectrum analysis picture when TX at 490M/+17dBm. It can say that the noise floor @1MHz is -42.43dBm, if add propagation loss 30dB, the noise floor is about -70dBm. Is the aforesaid weird RX performance related to this spectrum floor?
Best,
Tony Liu
--- Updated ---
