Hey!
Thanks a lot that is an eye opener.
I still have a quick question, assuming we have the following linear array:
X X X X X with feed [-2, -1, 0, -1, -2]dB.
In this case the mutual coupling is not reciprocal, right?
The extended question will be like. Assuming we have identical arrays like
X1 X2 X3 X4 X5
01 02 03 04 05
with the same feed scheme [-2,-1,0,-1,-2]dB
Now, HFSS simulates all the ports with the same power input, however we have 2 arrays, 5 elements each.
So, according to your suggestion I'd assume in this case that the expression would be like > (S(03,X2)/10)^2)*0.8W) .>> Is that true!
Thanks in advance
