Web based GUI Interface to FTP Server
Sanath Embedded
Member level 3
ftp web gui
Hi Guys,
I am successfully able to transfer the data to FTP server using GPRS Communication in SIM300/305 via FTP Protocol over the TCP Stack. So that data will be stored in respective files.
Now I want to access that data from the FTP Server and display the same over in a web page wth menu based display.So Can anyone help me on this like which platform I should go for and how I can do this.
sakaz
Junior Member level 1
web based ftp server
Hi Sanath ,
Great welldone. i want the do the same work i want to upload data to the website access database using ASP script.
You can get data from the file use ASP or PHP is powerfull.
Could you please provide me the AT commands how to connectip GPRS to the internet i am using APN i am not sure about these things.
Regards,
Shan
kambiz51
Newbie
interface for ftp
Hi Sanath
could you please tell me how to send data through GPRS to a static IP ?
i have tried to connect with Sim300 & result was good. i got a dynamic IP.
but i dont have any static IP to send & receive data .
is there any Free static IP to connect with ?
could you help me to see my data on the internet ?
All the best
srinivasareddy.t
Newbie level 1
hyderabad
Hi SANATH,
we could able create the file using FTP commands following below logged.
AT+CGATT=1
OK
AT+CIPCSGP=1,"xxx.xxx.xxx.xxx"
OK
AT+CGDCONT=1"IP","AIRTELGPRS.COM"
OK
AT+CSTT="AIRTELGPRS.COM","xxxxxxxx",""
OK
AT+CIICR
OK
AT+CIFSR
117.97.76.187
AT+CIPSTART="TCP","xxx.xxx.xxx.xxx","21"
OK
220 Microsoft FTP Service
CONNECT OK
AT+CIPSEND
> user anonymous
SEND OK
331 Anonymous access allowed, send identity (e-mail name) as password.
AT+CIPSEND
> pass
SEND OK
230-Hi Srinivas Reddy
230 Anonymous user logged in.
AT+CIPSEND
> appe abc.txt
SEND OK
at+cipccon=2
ERROR
AT+CIPSEND
> appe 123.txt
SEND OK
150 Opening ASCII mode data connection for abc.txtappe 123.txt.
425 Can't open data connection.
AT+CIPSEND
> appe tsr.txt
SEND OK
150 Opening ASCII mode data connection for tsr.txt.
AT+CIPSEND
> portxxx.xxx.xxx.xxx,7,228
SEND OK
500 'PORTxxx.xxx.xxx.xxx,7,228': command not understood
AT+CIPSEND
> port xxx,xxx,xxx,xxx,7,228
SEND OK
500 Invalid PORT Command.
AT+CIPSEND
> port 117,97,76,187,7,228
SEND OK
200 PORT command successful.
AT+CIPSEND
> appe test.txt
SEND OK
150 Opening ASCII mode data connection for test.txt.
at+cipccon=2
ERROR
AT+CIPSEND
> fdgdfgdfg
SEND OK
500 'FDGDFGDFG': command not understood
at+cmee=1
OK
at
OK
at&w
OK
AT+CIPSEND
> appe tdr.txt
SEND OK
150 Opening ASCII mode data connection for tdr.txt.
AT+CIPSEND
> get Bill1.pdf
SEND OK
500 'GET Bill1.pdf': command not understood
AT+CIPSEND
> appe abc.txt
SEND OK
150 Opening ASCII mode data connection for abc.txt.
at+cmgf=1
OK
at&w
OK
AT+CIPSEND
> dele abc.txt
SEND OK
250 DELE command successful.
AT+CIPSEND
> list
SEND OK
150 Opening ASCII mode data connection for /bin/ls.
at+cipsend
> size bill1.pdf
SEND OK
213 1132
AT+CIPSEND
> stor reddy.txt
SEND OK
550 reddy.txt: The filename, directory name, or volume label syntax is incorrect
AT+CIPSEND
> stor 123.txt,bin,ls
SEND OK
500 'STOR 123.txt,bin,ls': command not understood
AT+CIPSEND
> appe 123.txt
SEND OK
150 Opening ASCII mode data connection for 123.txt.
AT+CIPSEND
> appe 123.txt
SEND OK
AT+CIPSEND
> appe c:\netpeb\ftproot\123.txt
SEND OK
550 c:\netpeb\ftproot\123.txt: The filename, directory name, or volume label syn
tax is incorrect.
AT+CIPSEND
> appe rst.txt
SEND OK
150 Opening ASCII mode data connection for rst.txt.
AT+CIPSEND
> dele 123.txt
SEND OK
AT+CIPSEND
> dele rst.txt
SEND OK
AT+CIPSEND
> size Bill1.pdf
ERROR
AT+CIPSEND
> size bill1.pdf
at
OK
AT+CIPSEND
> size Bill1.pdf
AT+CIPSEND
> size BILL1.PDF
AT+CIPSHUT
SHUT OK
Please check these commands and reply,
Thanks and Regards,
Srinivasa Reddy
Shivashankarayya
Junior Member level 2
Bangalore, INDIA
Hi Sanath,
Please let me know how u did the data transfer to FTP server using GPRS Communication in SIM300/305 via FTP Protocol over the TCP Stack.
microKernel
Full Member level 3
NE
Re: ftp web gui
Sanath Embedded said:
Hi Guys,
For menu etc. you can use ASP.net. And you already know how to handle traffic to/from an FTP server. Just that the even handlers for buttons will execute the commands to FTP server.
paragbal
Newbie level 6
Re: ftp web gui
Hi Guys,
Hi sanath,
can u please tell us, how u had transferred file using FTP?? i mean using AT Commands, i m getting error as "425 Could not open data connection to port 3254: Connection timed out" in serial port, when i m sending MLSD from com port..
But when connect the GPRS through Dial up then using command prompt FTP working fine...?? i didnt understand why this happening??.... waiting for reply...
Thanks
farshchian
Re: ftp web gui
Hi Guys,
Hi Dear
Is it possible to explain how do transfer data with Ftp from GPRS to Remote Server FTP?
Regards
arun@darkside
Newbie level 2
Hi SANATH,
AT+CGATT=1
OK
OK
OK
OK
AT+CIICR
OK
AT+CIFSR
117.97.76.187
OK
CONNECT OK
AT+CIPSEND
> user anonymous
SEND OK
AT+CIPSEND
> pass
SEND OK
AT+CIPSEND
> appe abc.txt
SEND OK
at+cipccon=2
ERROR
AT+CIPSEND
> appe 123.txt
SEND OK
AT+CIPSEND
> appe tsr.txt
SEND OK
AT+CIPSEND
SEND OK
AT+CIPSEND
SEND OK
AT+CIPSEND
SEND OK
AT+CIPSEND
> appe test.txt
SEND OK
at+cipccon=2
ERROR
AT+CIPSEND
> fdgdfgdfg
SEND OK
at+cmee=1
OK
at
OK
at&w
OK
AT+CIPSEND
> appe tdr.txt
SEND OK
AT+CIPSEND
> get Bill1.pdf
SEND OK
AT+CIPSEND
> appe abc.txt
SEND OK
at+cmgf=1
OK
at&w
OK
AT+CIPSEND
> dele abc.txt
SEND OK
AT+CIPSEND
> list
SEND OK
at+cipsend
> size bill1.pdf
SEND OK
213 1132
AT+CIPSEND
> stor reddy.txt
SEND OK
AT+CIPSEND
> stor 123.txt,bin,ls
SEND OK
AT+CIPSEND
> appe 123.txt
SEND OK
AT+CIPSEND
> appe 123.txt
SEND OK
AT+CIPSEND
SEND OK
tax is incorrect.
AT+CIPSEND
> appe rst.txt
SEND OK
AT+CIPSEND
> dele 123.txt
SEND OK
AT+CIPSEND
> dele rst.txt
SEND OK
AT+CIPSEND
> size Bill1.pdf
ERROR
AT+CIPSEND
> size bill1.pdf
at
OK
AT+CIPSEND
> size Bill1.pdf
AT+CIPSEND
> size BILL1.PDF
AT+CIPSHUT
SHUT OK
Thanks and Regards,
Srinivasa Reddy
Thanks its useful
