Z
zenerbjt
Hello
We have a big indoor art gallery. Its a house full of art displays, each one will be lit up by a led lamp. Each LED lamp is about 40W continuous. There are 250 of the lamps. As such, the total power needed is 10kW.
We don’t want to use offline SMPS based LED drivers. This is because if the neutral gets accidentally disconnected from the upstream 3 phase supply, then the phase-to-neutral voltage may go up to 587Vpk, and this will blow up any offtheshelf Offline SMPS based LED driver. Therefore, we wish to use a 10kW, 3 phase mains 50Hz transformer, which steps down to three phase 40VAC outputs. We will then run this 40VAC along busbars…..then, we will use 250 simple 3phase, 6 pulse rectifiers. This will give us an approx. 55VDC output from which we can run the 250 SMPS based non-isolated LED drivers of 40W each…to feed each lamp.
My question is..
What do you think the efficiency will be? We believe we can get a 3 phase 10kw mains transformer at 99% efficiency custom built for around 10,000 pounds. Is this correct? Also, we will put an 10kW Active harmonic filter upstream of the three phase transformer to correct the power factor. What will the overall efficiency be concerning the Active harmonic filter and the three phase transformer?
We believe we can buy the Active Harmonic filter offtheshelf for £4000. Would you agree?
My question is..
