I'm trying to use a WD Passport 250GB and it is not visible.
How can I get Windows XP to recognize the drive?
Do I need a special driver for it?
My friend plugged it to his computer and it worked fine.
What's going on???????
If you think it's a driver problem - it's not, as many found out after much frustration ..
IT'S POWER PROBLEM ..
Get a shorter USB cable, or a power cable, and the problem disappears, confusing, eh!
The WD Passport hd requires a little over 1000mA of power at spin up, most computer systems only supply 500mA of power through USB ports ..
If it works with one computer has to work with others ..
Try different USB ports, in addition, some unconnected ports are also (usually) present on the motherboard ..
