waterproof speaker SIP network active voice pillar
sinrey
Newbie level 6
Newbie level 6
https://sinrey.com/Speaker_column/106.html
SINREY SIP742V is a wall mounted SIP network active sound column with 10 / 100M Ethernet interface, which can output and play the network sound source through its own power amplifier and speaker.
SIP742V can output and play the network sound source through its own power amplifier and speaker. It adopts waterproof design, and the power can be selected from 40W to 120W. It can be used in places where broadcasting is required, such as smart cities, campus broadcasting, parks and scenic spots, factories and enterprises, including Ping An community.
Features​
• Standard RJ45 network interface, providing firmware online remote upgrade;
• Based on ARM + DSP architecture, high-speed industrial chip is adopted, with startup time ≤ 1s;
• Built in decoding module, 40W power amplifier circuit;
• Provide 20W, 40W and 60W power options;
• Built in 4 4-inch full frequency high-quality speakers with loud sound, long penetration and clear;
• Outdoor waterproof aluminum alloy shell.
Parameters​
• Input voltage: DC 20V
• Power consumption: static < 300MW
• Working temperature: 0 ~ 65 ℃
• Power amplifier: 40W digital power amplifier
• Network interface: 10 / 100base TX adaptive network, RJ45 interface, 1.5kV electrical isolation
• Network protocol: support IP, ARP, ICMP, DHCP, UDP, DNS, IGMP, etc
• Audio playback: support up to 48K sampling, 192kbps code stream, MPEG and ADPCM decoding
• Specification: 100mm × 150mm × 620mm
