Mrunal Ahirrao
Full Member level 2
- Joined
- Nov 26, 2012
- Messages
- 133
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- India
- Activity points
- 2,213
Hi everyone,
I have developed a project which control all the water monitoring using PIC16f628A controller. The project works correct on prototype but fails on real time! All the code is followed correctly on prototype and when connected in Real situation it behaves strangely! As it works correctly on Prototype it means the code is correct, but in practical situation it fails.I have that its because EMI caused by relays. So I replaced Electromechanical relays with solid state relays. but it still behaves the same. In the enclosure I admit that the control PCB is very near to SSR's but I believe it won't create any problem.(am I correct)!?I am attaching the image of the system where its situated. The sad strange behaviour is it has been programmed t check waterlevel of lower tank first if it satisfies then switch ON the Pump and fill the overhead tank.this command works on prototype but don't on Real time instead of checking the water level it directly Switches ON the Pum when water is not there! Any help would be appreciated!
