burrow
Full Member level 2
- Joined
- Dec 15, 2014
- Messages
- 147
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 18
- Activity points
- 1,148
Hai,
i am using water level sensor made up using transistors, Before i was using leds so small fluctuations was not a big problem but now iam feeding a microcontroller, So i noticed that signal fluctuates. Something like from level 4, it shows level 6 for a second.
I think the water level probe is picking up raw voltages ( or whatever it is called )
In the transistor side iam using a 220 ohm resistor in the base, and also a 10k pull down.
Whats the solution?, will changing resistors to a higher value solve the problem?
