water level indicator
Chandu Nagabrahmam
Newbie level 3
Newbie level 3
hi guys..
Im doing project on water level indicator, I have designed water level sensor using transistor BC547.(circuit is attached)
The LED glows when probes touches the water. the output of the sensor is given to microcontroller.
I need some 5v to drive the port pins. but sensor output is below 3 volts. what can i do to get 5v and if I can amplify it, please provide the amplifier circuit.
sorry about the circuit, here is the one I have attached
why do you need a LED in the probe? You are losing 1v6 by including it. AC on the probe is generally preferred.
