Sajjadkhan
Full Member level 5
- Joined
- Sep 25, 2010
- Messages
- 307
- Helped
- 17
- Reputation
- 34
- Reaction score
- 16
- Trophy points
- 1,298
- Location
- Rawalpindi,Pakistan
- Activity points
- 4,199
Ok guys i know there are lots of methods out there to detect water level but i need a serious one because i am being paid for to detect water level and turning on/off the pump as required. The tanks are huge like 500000 Gal which are used to provide water to all the homes in that area. This is only one part of the project but its bugging me because they are asking me that sensors should work for no less than 5 years.
I have 3 methods of measuring water.
1. I am thinking of using Aluminum probes (as i think they are the best to use).
2. using IR method.
3. Using thermistor.
Problem with Aluminum probes:
1. When probes are in water and you apply voltage, electrolysis starts and its life decreases. i can increase its life by sending some very short voltage signals when required.
2. I have noticed that when tank temperature increases the water evaporates and if we use a weak pull up/pull down configuration it will false trigger due to that moister around the probes which helps in conduction. and if i use strong pull up/pull down resistors then it may happens that water conductivity (due to any reason) changes and it wont trigger.
3. I don't have any idea that what effects will be on that probes when they are submerged in the water for long time.
Problems with IR method:
1. It can be use to detect only top level since it floats on top.
2. I can use them in water but i don't know the water condition i.e. how much pure the water is (clarity point of view).
Thermistor is attracting me because i can fix it in some thin Aluminum pipe which will be sealed. there will be some current flowing through the thermistor which will heat it up. when that single Aluminum pipe probe touches the water thermistor current will reduce and i can use that as a detector.
So if you guys have any suggestions then do hit me. Remember i need long life span sensor and minimal maintenance or none.
2. using IR method.
