if countdown is used , then it will be easier for generating interrupt
in hardware module as rollover from all zeros to ones , (the underflow)
can be taken from the msbit.
otherwise , if countup is used you must have a comaparator also to compare and interrupt at the specified time.
countdown doesnot require a comparator. only the carrbit out of msb can be used for interrupt.
it is reduction in hardware , why countdown is used.
You are saying a rollover from all zeros to ones (ie count down) can be used to generate a interrupt by utilizing the MSB Bit, but interrupt can also be generated by a rollover from all ones to zeros (ie count up) by utilizing the MSB Bit correct ??
