WARNING:Xst:2677 - VHDL
lanfeust129
Newbie level 2
Hello,
I've got a problem with my VHDL code. The warnings are :
WARNING:Xst:2677 - Node <half_sync_entries_2> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <half_sync_entries_3> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <half_sync_entries_4> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <half_sync_entries_5> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <sync_entries_2> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <sync_entries_3> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <sync_entries_4> of sequential type is unconnected in block <synchronisation_top>.
WARNING:Xst:2677 - Node <sync_entries_5> of sequential type is unconnected in block <synchronisation_top>.
That's the code in top.vhd
component synchronisation
    Port ( D : in  STD_LOGIC;
           I1 : in  STD_LOGIC;
           I2 : in  STD_LOGIC;
           A : in  STD_LOGIC;
           S : in  STD_LOGIC;
           P : in  STD_LOGIC;
           test : in  STD_LOGIC;
           reset_n : in  STD_LOGIC;
           clk : in  STD_LOGIC;
           sync_test : out  STD_LOGIC;
           sync_entries : out  STD_LOGIC_VECTOR (5 downto 0));
end component;
synchronisation_top : synchronisation
	port map (	D => D,
					I1 => I1,
					I2 => I2,
					A => A,
					S => S,
					P => P,
					test => test,
					reset_n => reset_n,
					clk => clk,
					sync_entries => sync_entries,
					sync_test => sync_test
And in synchronisation.vhd
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity synchronisation is
           I1 : in  STD_LOGIC;
           I2 : in  STD_LOGIC;
           A : in  STD_LOGIC;
           S : in  STD_LOGIC;
           P : in  STD_LOGIC;
           clk : in  STD_LOGIC;
end synchronisation;
architecture Behavioral of synchronisation is
SIGNAL half_sync_entries : STD_LOGIC_VECTOR (5 downto 0);
SIGNAL half_sync_test : STD_LOGIC;
begin
HALF_SYNC: PROCESS(clk,reset_n)
BEGIN
	IF reset_n = '0' THEN --reset asynchrone actif bas
		half_sync_entries <= (OTHERS => '0');
		half_sync_test <= '0';
	ELSIF clk'EVENT AND clk = '1' THEN --flanc montant du signal clk
		half_sync_entries <= D & I1 & I2 & A & S & P;
		half_sync_test <= test;
	END IF;
END PROCESS;
BEGIN
		sync_test <= '0';
		sync_entries <= half_sync_entries;
		sync_test <= half_sync_test;
	END IF;
END PROCESS;
end Behavioral;
I know it's a bit messy (and I don't really need half_sync_entries for example) I just want to know why it say that it's not connected...
Thanks
It will be something at a higher level, what are D, I1, I2, A, S P connected to?
