Michael Weaser
Member level 3
I have been wanting to build a clone of the voder. I know mostly how the Voder works , since it is based off Homer Dudleys' Vocoder design in which who is also the designer of the Voder. The circuitry of the voder is simply the 2nd half of a 10 filter vocoder , the decoder part , hooked up to a resistive keyboard . As you pressed down on the key to a particular filter the output would get louder and louder.
To play vocal sounds, you had to be really precise on how you pressed the keys. The keys had to be pressed at the correct resistive levels , and with exact timing to have it say words and sentences.
What I need help with , that isn't in the patent information ( which there is a pdf uploaded )
1 . figuring out how the voice changing works , which is probably done by modifying and adding signals to the the 2 sound generators or modifying the output of all the filters .
2. figuring out the 3 extra plosive keys and what filters each key controls , originally plosive sounds where created by swiping keys really fast to make plosive sounds, eventually automatic circuitry got added that does this for you.
The Voder is going to hard to learn to play , as there is no information on how words than turned into sentences are played on the voder on the internet. There is information on how individual sounds are made , and that's it. A guy named Stanley S. A. Watkins is the one that figured out how to play the voder.
Technically there is a manual that exists that Stanley Watkins wrote on how it is played , but only 2 people other than bell labs have it , one of those people is actually Stanley Watkins daughter, and the other guy , is another person who designed a clone of the Voder for bell labs, Bell labs doesn't want the documents released or put on the internet for some reason. I have talked to the daughter of Stanley Watkins about these issues.
A handful of ladies where trained to be able to play the Voder accurately , only a few passed.
