Want to understand following specification terms for Home Theater 2.1
shroff_rushi
Junior Member level 3
Need to know exact definition of following terms..
PMPO output, Source input, Frequency response, S/N ratio, Distortion, Output Power, Separation, Input sensitive, Hum-noise output, Satellite impedance, Subwoofer impedance, Power consumption, Power supply SMPS Type, Satellite Dimension, Subwoofer Dimension
Audioguru
Advanced Member level 5
Toronto area of Canada
Those are very basic English words.
1) Learn the English language.
2) Look at the definition of the words in a dictionary.
3) Look at the words in Google.
RITESH KAKKAR
Banned
INDIA
peak music power output
the dependence on signal frequency of the output–input ratio of an amplifier or other device.
Signal-to-noise ratio (abbreviated SNR or S/N) is a measure used in science and engineering that compares the level of a desired signal to the level of background noise. It is defined as the ratio of signal power to the noise power, often expressed in decibels.
what are you doing ?
