Want to transmit GPS data using radio transmitter?
angy
Full Member level 3
i am looking for a design solution in which i receive a GPS data and want to transmit
it using radio transmitter.
KlausST
Super Moderator
Staff member
What is your question? Hardware? Software? Complete solution?
Did you do any research on your own?
A possible solution:
There are many GPS modules communicating with UART.
There are many Bluetooth-to-UART modules.
Connect both any our are finished.
Klaus
angy
Full Member level 3
It will be like.
Satellites-> GPS Tracker(Tx/Rx)-> radio receiver-> radio transmit-> Network(World wide web etc)
The tracker is able to determine the precise location by receiving position signals from GPS satellites with its GPS receiver. The tracker then uses radio transmitter to transmit its position to a network. The network can be either ground or satellite-based.
I am looking for a hardware module which has a GPS tracker and radio receiver on a same board.
KlausST
Super Moderator
Staff member
thats´s exactely what the GPS trackers do, you can buy on ebay for example..
Klaus
davenn
Advanced Member level 3
Sydney, Australia
The tracker is able to determine the precise location by receiving position signals from GPS satellites with its GPS receiver. ....................
what's your definition of precise ?
Publically available precision is around 10 - 15 metres where only one receiver is used
Klaus
indeed or as example, this one .....
Dave
