want to save a string in memory and then transmit on serial
j hemangini
Member level 1
I want to save a string let "I am testing serial" on a memory address and then read each character one by one from that memory address.
So please tell me how can i define a memory address ,and can save this string on that address.
thank you.
j_andr
Full Member level 4
europe
Re: want to save a string in memory and then transmit on ser
j hemangini said:
I want to save a string/.../
I'm not sure if I understand the requirement correctly ...
if you mean:
"i want to store 4/8/16/? bytes in a memory as a
parallel word and then read them out byte by byte"
you can:
- create a mux at the output of the memory;
- push byte by byte of your test word to a fifo using a mux
at the input;
j hemangini
Member level 1
But firstly how can i save this sentence (I am testing serial) in the memory . Means how can i write it in vhdl code. I have spartan-3a starter kit on which i have to do this work.
Thank you.
avimit
Banned
Fleet, UK
You will have to save a binary code corresponding to each character in your sentence in a memory. Then use VHDL model to read the memory and transmitt it. For strings using 'ascii' codes as binary codes is a good idea.
kr,
Avi
j hemangini
Member level 1
Ok.
Now can u tell me how can i define an array , and how can i access byte by byte from that arry.
If i want to define an array having values[1,2,3,4,5] etc ,and want to access each values one by one then how can i write it in vhdl code?
zape
Full Member level 2
Spain
Reading your questions it looks like if youwer not familiar with FPGAs. FPGAs are hardware not SW.
What type of serial comunicaton do you want to implement? Synchronous, asynchronous?
ihearme
