vpp on epic programmer please help
Eddy25
Newbie level 2
Can't get vpp 13,5v with epic programmer. The max i can get by changing the value of the variable resistor is 12,65V. I'm using a 15V- 1A dc adapter. What may be the problem.
Thanks.
mvs sarma
Advanced Member level 3
Hyderabad, India.
Thanks.
With the application of DC, the bridge will drop 1.4V,the balance DC is not sufficient for 7812 with a diode in the common. It needs at least 3V higher than expected output.
You may apply 15V AC from secondary of the adopter direct.
Eddy25
Newbie level 2
Thanks. Have used a 18v dc adapter and everything is OK.
