semiconductor
Full Member level 4
7107 digital voltage meter
I've just bought Voltage and Current Meter with Digital Display. I found on the PCB 3 main ICs:
- TL431
- CD4069 (inverter)
- ICL7107
With the Voltage Meter, Everything seems to be ok. when I power it let the in put 0V, I mean, I connect the (+) pin and (-) pin of the INPUT, it displays 00.0 V without fluctuation.
But with the Ampere Meter. I'm facing the problem: When I power it, and connect (+) to (-) to simulate the fact that: no current appears. It floats around 0.6V
I'm wondering why????
When I looked at the PCB, the twos are the same except that, some resistors around TL431 are different.
Can you recommend me some possible reasons relating to ZERO FLOATING phenomena with the IC TCL7107???
- TL431
- CD4069 (inverter)
- ICL7107
