seyyah
Advanced Member level 2
I have a circuit that converts voltage into current referenced to ground of the circuit. Output is 4-20mA. What happens if i connect this output to a current loop receiver? Should all current receivers supply supply voltage? If so, two different voltage sources will be combined i think. Should we use current loop transmitter with the current loop receiver and current transmitter with the related receiver? Can you enlighten me about this subject?
