chinuhark
Member level 5
- Joined
- Aug 16, 2014
- Messages
- 88
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Activity points
- 1,051
I have wanted this for a long time now so I would just go ahead and ask.
I would like to know if there is a cheap IC that directly takes in an analog voltage (say 0-10V or 0-5V) and converts it into PWM of desired switching frequency and duty cycle should vary from 0-100% according to the analog input.
Now the traditional way of doing this is making a triangular wave generator and using a comparator to compare it to the reference input. What I do is use an Atmega 8 and use ADC and PWM out for doing the above.
Please suggest a cheap and easy to find IC that can do the above in 1 small single package.
I would also like to add that it should be fixed frequency PWM which can be set as required
