Voltage to Frequency Converter application
robismyname
Full Member level 6
Central Florida
voltage to frequency converter applications
I have an application where a v to f converter is needed. "AD654"
I have 1 Volt coming in on Vin. And I want a desired Fout of 100Hz (min) - 2000Hz (Max). How do I use this part to obtain my desired Fout? Any/All help appreciated.
Aya2002
Iraq
v to f converter
This called the Voltage Controlled Oscillator (VCO)
biff44
Advanced Member level 5
New England, USA
I prefer to think of them as voltage-to-phase integrators.
robismyname
Full Member level 6
Central Florida
applications of voltage to frequency converters
Yes I am familiar with VCO operation. I have a requirement for a square wave output. Do VCO's typically give square wave outputs?
biff44
New England, USA
v to f converter applications
I see your point. It would be impossible to turn a sine wave output into a square wave output.
FvM
Super Moderator
Staff member
Bochum, Germany
voltaga to frequency converter
You'll find the design equations in the AD654 datasheet.
robismyname
Full Member level 6
Central Florida
ad654 applications
I'm connecting pin 4 of the V to F converter(AD654) to pin 7 of the SA636. Looking at the pin function of pin 7 of the SA636 what would be the max voltage? Vcc?
yendori
Full Member level 2
frequencu to voltage converter+applications
