Voltage stabilization
Ungi
Newbie level 1
I want to measure the voltage with PIC, I created the following circuit:
this is the signals,
I want to shift the output voltage, but unfortunately the shift voltage(green) is depending from the input(following the input). How can I stabilize this voltage, because I want 1.65V.
Use an adjustable Low Voltage Reference, example TL431 :grin:
or you need to recalculate resistors, in order to obtain the necessary results, see
The voltage at R8/R9 junction is being loaded.
You have R7 and R3, in series, from the junction of R8/R9, to earth via V6. Likewise V6 is loaded by the reference voltage circuit after R3.
To eliminate the problem, replace R7 with an op-amp voltage follower.
If we use a buffer need to keep the R7 in the circuit.
Also, same problems, R6/R7 (in the original circuit) need to adjusted down to 9.9K. :grin:
