asrock70
Full Member level 4
Can you advise how to solve the voltage reference for 24bit ADC so as to have the least impact on the accuracy (les LSB) of the ADC?
For example 24bit ADC AD7763
in datasheet say suitable reference is ADR434. I thnig NO!
24bit ADC have LSB 0.059ppm and ADR434 have TC 1ppm/C ==> error 17digit/C
They ADR434 supplemented by two pole LPF with -3dB on ~15Hz and -35dB on 1kHz. ADR 434 have noise 0.1Hz - 10Hz 6.25uVp-p
I admit I can not quite tell what the impact of noise on the precision reference ADC.
Can you advise?
Can you advise?
