Re: Voltage Noise
> Gain, usually means differential gain, acts upon wanted signal.
>Noise, regarded as common-mode at the input, gets rejected by means of
> common-mode rejection.
Of course, that are basics of in-amps
> For output noise, you should consider noise injected from amp + noise due to loading.
I thought im doing it ... I think that input referred Output noise (as stated in datasheet) is the noise added by the in-amp. There are no others figures considering noise so it must be it ...
The common-mode noise is not so interesting while reduced by 110dB as stated in the datasheet.
