T
treez
Hello,
Please check the Small Signal power stage transfer function of a Voltage mode, DCM Flyback as given on Equation 17, page 12, of AN-57 by Power Integrations...
AN-57:-
https://ac-dc.power.com/sites/default/files/product-docs/an57.pdf
This equation is very different from the one (equation 2A-20) given by Dr Basso on page 232 of his book “switch mode power supplies” (page attached below).
(Basso’s equation 2A-20 is for a buck-boost, but as you know, this is the equivalent to the flyback)
(Incidentally, “Vpeak” of equation 2A-20 refers to the peak of the voltage mode ramp generator)
When the above Equation 17 is used to calculate the open loop bode plots, it gives a nonsense crossover frequency value of 100khz (above the switching frequency). The excel document that I used to do the bode plots using Equation 17 is also attached.
AN-57:-
