voltage limiter and current feedback op amp
EDA_hg81
Advanced Member level 2
I am using current feedback op amp to realize voltage limiter.
why the output is only -10mv to -80mv?
FvM
Super Moderator
Staff member
Bochum, Germany
- The VSS supply has wrong polarity.
- +2/-3V is below AD8002 minimum supply voltage
- The supply voltage is too low to reach the zener voltage
- A current feedback OP requires a Rf resistor in a specified range around 1 k to set the loop gain. It doesn't allow e.g. limiting diodes or capacitors in parallel.
- Zener diodes don't work for high frequency limiters
    EDA_hg81
EDA_hg81
FVM,
Would you let me know how to design high frequency limiter?
Thank you.
Added after 40 minutes:
May I use the rail to rail power supply as voltage limiter since the output voltage only can rearch power supply.
if the power supply is +4V to to -4V, the output only can rearch +-4V.
vistapoint
Member level 5
You may add a cap in parallel with R to form a 1st order low pass filter.
Your opamp usually has requirements on voltage supply. So using supply as limiters is not a good solution.
Low price resistors, capacitors, and LEDs: **broken link removed**
EDA_hg81 said:
FVM,
Thank you.
    EDA_hg81
FvM
Super Moderator
Staff member
Bochum, Germany
You may not add a cap in parallel with R - in case of a current feedback OP.
    EDA_hg81
aomidee
Junior Member level 1
Tehran,Iran
to have a high frequency limiter,just replace two Zeners with one cap and use a lower resistance . but it wont feedback the current as good as your previous circuit! in this case, the feedback factor will vary with frequency, and you know that it is a filter! so, some parts of input signal wont be feedbacked! I think so but simulate it to reach certitude!
    EDA_hg81
EDA_hg81
aomidee
Thank you so much and happy holiday!
