Voltage level in cell and power gating switches in multi-Vdd design
kimthi
Newbie level 6
Hi all,
Please help me!
I want to know about multi-Vdd library.
How many voltage level are there in each standard cell? [Not include: special standard cell ]
Power gating switches are used in multi-Vdd design=> what for?
Thanks,
cafukarfoo
Full Member level 3
Re: Multi-Vdd design
You can have any number of different vdd supply in your design.
For multiple vdd design, you have level shifter to connect between 2 different power domain. So in the level shifter cell, you will have 2 different power port connect to different power level.
I believe power gate switch is used to turn off certain core area that operate on certain power domain when that power domain is not in use to save power consumption. I believe the concept is something like clock gate to turn off certain clock tree that is not in used.
Hope this help. Thanks.
kimthi
Newbie level 6
Multi-Vdd design
Thank you,
Ya, the level shifter has 2 different power port connect to different power level.
The isolation cell is place between floating points.
I means:
The standard cell that is the most in multi-vdd design. How many power supply in them?
Do all the standard cells have two or more power supply?
--Regards,
cafukarfoo
Full Member level 3
Maybe i don't understand your question clearly.
Normal standard cell should just have 1 power supply. This standard cell had been characterized using 1 power supply.
Let say your design have 3 power domain ( A, B and C )
type 1 standard cell will be placed in power domain A. This standard cell will have 1 power port connected to the power net A. And the same with B and C.
So for summary, although you are in multivdd design, your normal standard cell(flop, buffer, mux, adder ) should just have 1 power supply.
avimit
Banned
Fleet, UK
There can be mixed Vt(threshold) Cells in your design. Are you sure you are talking about multi vdd and not multi Vt cells?
Kr,
Avi
https://www.vlsiip.com
Thinkie
Full Member level 3
Multi-Vdd design
Cells always have one power source. Multi VDD has many power islands but all cells in the island have one power source
MultiVT however, you can mix High and Low leakage cells... they still have one power source
kimthi
Newbie level 6
Multi-Vdd design
What's AON cell? Is it always_on cell?
Do we use it in multi-Vdd design?
The function of AON cell, retention flop, power gating switches and enable level shiter?
Do you know about them? Plz tell me ...
forkschgrad
Full Member level 5
Philippines
hi kimthi,
see https://socdesignsource.org/magicbluesmoke/?p=20
i hope this helps
fork
