hans_r
Newbie level 5
I'm using the UMC180nm technology to design an image sensor: the thick oxide 3.3V transistors are used for increased swing when sensing the light. I want the digital parts of my circuit to work on 1.8V (reduces area!). I'm using a thick oxide inverter attached to 1.8V in stead of 3.3V. In Spectre this works, but it gives the warning that the bulk-drain junction leaves the linearized region. I know this is because of the high Vgs voltage at the pMOS when the input is 3.3V. Is this detrimental to my circuit, or will it work? Or is there maybe an other way to interface to the 1.8V transistors with the 3.3V?
Thanks!
Thanks!
