an_82
Member level 2
- Joined
- Oct 6, 2013
- Messages
- 52
- Helped
- 7
- Reputation
- 14
- Reaction score
- 7
- Trophy points
- 8
- Location
- Delft, Netherlands
- Activity points
- 303
Hi every body,
I need a simple analog circuit consist of only MOS transistors to do this:
Vo=(V1+V2)/2
Where V1 and V2 are DC voltages less than 1v. By the way the V2 can be negative e.g. the circuit should be work for (V1-V2)/2.
If you have idea by using resistors it works for me. I can replace the resistors by MOS transistors in linear region.
thanks
Vo=(V1+V2)/2
thanks
