Visual C++ 2008 Question: How to read a text box into an array
Felis_Silvestris
Junior Member level 2
San Jose, CA
I’m totally stuck.
Here is what I’m trying to do:
I’m using Visual C++ 2008 and built a form that uses a text box
The user enters a four digit alphanumeric code into the text box.
I read this text using: textbox->text
Next, I need to separate the four digits into ASCII code.
The ASCII code of each character is placed in this array (exactly like this)
InputBuffer[2] = <ascii code of first digit>;
InputBuffer[3] = <ascii code of second digit>;
InputBuffer[4] = <ascii code of thrid digit>;
InputBuffer[5] = <ascii code of fourth digit>;
can u tell what is the application type (MFC or win32) ?
if i assume you are using MFC, then i think textbox->text should be a CString object, and you can call textbox->text[0], textbox->text[1] etc..., to extract the ascii code of the digits.
